Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-13-2005, 07:06 PM
CoachRick CoachRick is offline
Send a message via AIM to CoachRick
Question about Ventalation 94 Tbird
Hi all, I am new here, so I will behave. :-)
I have just bought a 94 LX with climate control. Problem is this car was used by a smoker, and when I turn the A/C on there is a very strong cig. oder from the air. Is there a filter that is replaceable in there, and if so how do you get at it?
Thanks....cough....cough....Alot!
Coach
Old 09-15-2005, 04:48 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Question about Ventalation 94 Tbird
No filter that I know of. The smoke has coated the inside of the ventilation system. The first thing to try is to remove the blower motor and clean inside the housing as far as you can reach in both directions. Then reinstall the blower, turn on the system and spray some Lysol or something like it into the fresh air ducts on the cowl. This won't cure the problem for good since you haven't cleaned inside all of the ducts but it will help some. You might want to ask someone at an automobile reconditioning place what they use. Good luck.
Old 09-15-2005, 09:34 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
There are companies that will "smoke bomb" your car. They will spray the fabric areas with a product similar to febreeze and spray smoke into your car that gets into all the ductwork, inside the dash, under the seats, anywhere they can't spray. After they spray/smoke your car they shut the doors for about 15 or 20 minutes then open it back up to let it air out. It works really well to neutralize odors from pets, smoking, mildew, etc.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-16-2005, 11:07 PM
coondawg6 coondawg6 is offline
you can go to a auto parts store and ask for evaporator and duct cleaner and freshener. good stuff is about $8-$10 bucks a can and follow directions on can. another way is find a repair shop that uses a product named dwd2. it uses a chemical and a machine to "power wash" you ac ventilation system costs between $150 and $300 dollars depending on area you live and how nasty it is, but well worth its cost
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
