Old 09-13-2005, 05:15 PM
GunsnRoses88's Avatar
GunsnRoses88 GunsnRoses88 is offline
Send a message via AIM to GunsnRoses88
Anyone please help i need door panel off 92
i cant figure out how to take off the door panel ,,, i get everything off and then the handle to get out of the car is a problem... there is one screw to get it loose or something then i have to pull the door panel away from it and i cant get it loose,,,, please help!!!
Old 09-13-2005, 08:29 PM
AccordCodger AccordCodger is offline
Re: Anyone please help i need door panel off 92
door handle is held with one screw under a round plastic cover. Remove the screw and slide the handle assembly forwards (I think). Pull out gently, push the tiny plastic retainer back and unhook the metal rod. The handle will then be free. After that, if you have the clips loose. lift the panel upwards to disengage it from the door.
Old 09-13-2005, 10:06 PM
what is the tiny plastic retainer?
Old 09-13-2005, 10:11 PM
mpumas mpumas is offline
It is a clip that holds the rod that that goes to the door lock to the door handle.
Old 09-13-2005, 10:25 PM
oh so in order to take off the door panel, i must first unscrew the one screw in the handle and take the rod out then unclip the panel? i always had the door panel all unclipped and hanging trying to get off the handle,,, i guess it didn't leave me enough room to work with if i am taking this in correctly
Old 09-14-2005, 01:03 AM
Yep
