Old 09-13-2005, 05:11 PM
olli251 olli251 is offline
help, i dont know what to do.
I have currently purchased a 1997 s-10 blazer. about three days after i bought it i had a problem, i was driving like 40 mph, when the speedo dropped to zero mph, the abs light came on, and the tranny shifted into second gear. the tranny stayed in second until i gave it enough gas to shift on the regulator appox. 4500 rpm, at which point it shifted into third. when i leave it sit it doesnt change anything. the only way for me to get the speedo working, and tranny shifting, is to shift the tranny on the regulator hard,,(my foot on the floorboard) then the speedo comes up, the abs light goes off, and it shiftsd normally. is it a vss or the exciter ring, if so how do you fix the problem.
Old 09-13-2005, 05:17 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: help, i dont know what to do.
VSS pickups are easily swapped. However, use the search function to look up "97+Ignition+Switch". Swapping the VSS at first may be the cheap fix, but the odds are against you that it's a pesky switch - 97's are infamous for them.
Old 09-13-2005, 05:24 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Do a google search on this number.
01-07-30-002c
It will take you to a service bulletin about this issue.
Old 09-13-2005, 05:49 PM
blazee's Avatar
blazee blazee is offline
Problem?
It has been updated to 01-07-30-002d. I've got it, but I'm in the middle of a large download right now. I'll upload it and post a link in a few minutes.
Old 09-13-2005, 05:59 PM
blazee's Avatar
Problem?
Okay here it is:
http://files.bighosting.net/wk81267.pdf
His problem doesn't sound like the typical ignition switch failure. I would do a little more investigation before changing any parts.
Old 09-14-2005, 12:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, ignition switch.
1995 Factory Blazer Service Manual for sale, PM if interested.
