Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-13-2005, 04:06 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Question no clue... wtf
Alright guys, so i just put on new spark plug wires and a couple of days later the shite hit the fan. Most every time i really hit the gas the car almost stalls out, only when i try to rev it up, if i just press the gas slightly it will run fine. So i was thinking it had to be something with the wires but i checked and all of the sparks are good. Then i made sure all the cylinders were running and they are. Then i looked at the throttle body and it looks good from what i can tell.
I just had changed tha spark plugs as well so those should be fine bu ti now have no idea what could be causing it. i did some research but couldnt find anything about it stalling only when reved up high (plus it doesnt completly stall just goes down to like 300 rpm and then if i let off the gass it will catch itself so im lost please give me some ideas thanks.
Old 09-13-2005, 07:02 PM
Chuki_breath Chuki_breath is offline
Re: no clue... wtf
well did you get the right plugs???? Maybe gapped to much or less or something. I dunno. I would assume everything is hooked up right since your getting actual spark. Is this on a totally stock engine or sr or what?
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 09-13-2005, 08:50 PM
monooxide's Avatar
monooxide monooxide is offline
Banned
Send a message via AIM to monooxide Send a message via MSN to monooxide
Ok...
Before ruining these plugs and washing all the oil off your cylinders walls with gas... Check the gap on the plugs most likely its too big. Stock gapping is .032 i believe
Old 09-13-2005, 09:53 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
Re: no clue... wtf
.044
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 09-13-2005, 10:30 PM
liquidPunk's Avatar
Re: no clue... wtf
thanks guys. This is a stock Kad motor, the plugs are good and the correct ones, thats why im so confused, but i guess it could be the fuel filter mabye?? it is just wierd to me that it runs fine untill i punch it. anything else you guys can think of? thanks again.
Old 09-14-2005, 02:20 PM
liquidPunk's Avatar
Re: no clue... wtf
well... put in a 300 fuel filter and that helped a little but barely, still the same mostly, i guess ill try the pump, mabye get a walbro what do you think?
Old 09-14-2005, 11:14 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: no clue... wtf
good investment.. sounds like that could be the problem. you're not leaking fuel anywhere though are you??
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 09-15-2005, 10:14 AM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: no clue... wtf
Sounds like typical IACV or AIV problem to me.
Check the FAQ at http://www.240sx.org
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 09-15-2005, 02:37 PM
shawn_carter69's Avatar
shawn_carter69 shawn_carter69 is offline
sounds like the throttle position sensor possibly, i dont know though i had the same problem with my hardbody, a lot of similarities right. just something to think about but id look into the fuel delivery but who knows.
let me guess you can go fine to about half throttle then it cuts out?? if thats what it is its just like my hardbody and its in 'limp' mode, the ecu dont want anymore damage done, actually doesnt mean it is th tps, just that the ecu has the vehicle in the limp mode. it'll stay there til you fix the problem.
if thats what it is.
10 Fusion SE I4 - DD
93 Talon TSi - project
Old 09-15-2005, 07:35 PM
liquidPunk's Avatar
Re: no clue... wtf
There is no fuel leaking anywhere (checked injectors and underneath car and soft fuel lines). Ill clean the AIV after work tomorrow, mabye thats it, thanks. it does seem the same as your hardbody, "limp mode" is that a problem with the actual ECU or something mechanical that i can fix? Im pretty much willing to try anything, its really starting to get on my nerves because those damn civics think my car is shit now. anyway the fuel pump is a good upgrade anyway so thats cool, all the help is great guys. ohh... what is the output for the stock fuel pump? just wondering
Old 09-16-2005, 09:12 PM
what it is, the ecu wont let the motor rev too high until whatever problem has tripped a fault code has been fixed and the fault code is cleared
