is it the starter?
on my 88 auto 2wd pioneer i cleaned the cap and rotor and it hasnt started since. prior to that the previous months it has taken a little longer to start but not that bad.
i havent put juice to the starter directly to see it it is dead as i am unsure exactly how to go at it other than disconnecting it running cables to the starter i guess with the key in on position. the battery is new rechecked and charged up to spec next day after the strand/tow and a new cap rotor installed, the dash lights up but it just wont turn over nothing at all no clicking. i hear what sounds like the fuel pump working also. i haveread here that the neutal safety switch can be the problem needing only removal cleaning then regreasing.....any suggestions? need my jeep for work bad and have to use a german 4 cyl in its place for now and it just aint the same. |
Re: is it the starter?
put it in park turn the key on and take a rubber handel screwdriver and the touch the positive and the ground at the same timeon the starter. i have to do this sometimes with my jeep. i dont think mine goes in to park half the time.try to put your gear shifter in park a couple of times and see if that works.]good luck!
Re: Re: is it the starter?
thanks i will look for the switch troubleshoot before appraching the starter though. |
