Old 09-13-2005, 02:22 AM
Moe24 Moe24 is offline
Question 97 Blazer lift
Does anyone know what the best and most cost effective way to lift a blazer is? I only want to lift it about 3". 4 at the most.
Old 09-13-2005, 02:53 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Re: 97 Blazer lift
trade in what you have now for a ZR2
Old 09-14-2005, 06:16 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Do you want a body or a suspension lift? A body lift will run you about 150 bux. A suspension lift will run you about 1200. You don't want to go with the smaller lifts. Why? Because every lift kit out there doesn't properly change the geometry of the front end suspension. You will end up going through ball joints like you do underwear. The trailmaster 5" is the only 5" that keeps the stock geometry. There is a 6" out there that does well too but I can't remember the name off hand.
Old 09-14-2005, 11:51 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Blazer lift
Is this a 2wd or 4wd truck?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-15-2005, 09:59 PM
2WD or 4WD
It is a 4WD the everything is original except for what has been changed with maintenance cycle and a few other minor things in the interior.
Old 09-22-2005, 01:36 AM
spblend spblend is offline
The Trailmaster Kit your lookin for is this one...
CT15SSV its a 5inch Trailmaster kit, ull need to mod ur exhaust a bit and some frame bracket cutting but thats bout it.
lookin at around probably 1300US-1400US for that.
Old 09-22-2005, 01:53 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: 97 Blazer lift
Body lift is much easier and cheaper , I did both . A 2" suspension lift comes with new upper control arms to keep the front end geometry correct . I spent $600 on my combined lift to gain 7 inches to the seat . Rob
