Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 09-13-2005, 01:06 AM
toon-guy toon-guy is offline
3800 Spark plug wires
Does anyone know how to release the rear bank of plug wires?
I can reach them but I feel some kind of covering that won't release when I tug.
Old 09-13-2005, 05:48 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 3800 Spark plug wires
The wires have metal RF shields around them. You can pull on these with your hand and they should bring the plug wires off with them. You just have to pull to get them off. Make sure to replace them with the new wires.
Old 09-13-2005, 10:37 AM
Re: Re: 3800 Spark plug wires
THANK YOU -- I GUESS I'LL HAVE TO PULL HARDER!
Old 09-13-2005, 12:46 PM
daman daman is offline
Twist a little too.
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 09-17-2005, 12:31 AM
Re: Re: Re: 3800 Spark plug wires
ACTUALLY I JUST GOT ANGRY ENUFF TO HAVE THE STRENGTH TO GET THEM OFF!
AFTER SWITCHING THE WIRES THO I SEEM TO HAVE THE STUMBING EFFECT WHEN THE CAR DOWNSHIFTS!?
ARE THERE SOME LIITLE CHIPS OR VALVES THAT MIGHT BE CLOGGED?
Old 09-17-2005, 06:46 AM
Re: Re: Re: Re: 3800 Spark plug wires
Old 09-17-2005, 08:31 AM
kok328 kok328 is offline
Did you change the plug wires with new ones?
Did you change them one at a time?
I'm guessing that you have a bad wire (new ones can be bad) or you don't have the firing order correct.
Old 09-19-2005, 09:18 PM
It's running much smoother -- only stumbles when downshift into 4th gear.
Is the egr valve the plastic army-helmet looking thing?
A verticle cyclinder to the left of the air intake?
I found a horizontal small black pipe thing on the right rear and unplugged that -- but no change at all.
Old 10-09-2005, 02:26 PM
Still stumbling
OK, New plugs, new wires, EGR unplugged, injectors cleaned and rocket fuel in the tank.
Runs strong and great -- but as soon as it downshifts -- bumpy ride all over again.
New thoughts?
Thank you!
Old 01-23-2010, 12:05 AM
kjlundgren kjlundgren is offline
Well when it rains it pours. I've found that once a tale light goes out you have to buy out autozone before it runs like it used to.
If the engine es not miss-firing after the downshift but you get a crappy ride it could be something in the tranny.
