Old 09-12-2005, 11:16 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Clutch engages with pedal to floor
If I put my 94 tracer into 1st while stopped and have my foot on the clutch it will automatically engage like fluid is leaking. There are no visible leaks anywhere and I have bled the system numerous times. Also the fluid is full.
I have concluded that it may be the clutch master cylinder. I was just wondering if the brake master cylinder has anything to do with this also?
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 09-13-2005, 06:55 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Clutch engages with pedal to floor
In my 99 escort the clutch and brake fluid are one unit. However being hydrolic there is (i assume) a slave cylender near the clutch fork. Possible that could be leaking (I dont beleive it would be enough to see a puddle though)
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 09-14-2005, 07:21 AM
mustang302 mustang302 is offline
The clutch master cylinder uses brake fluid it taps off of the brake fluid reservoir. I'd first check the level in the brake reservoir and then see about bleeding the clutch slave cylinder, there is a bleeder valve on the front of it. If that doesn't help or you can definitely isolate one of the cylinders as leaking, replace it (they're cheap). I found my master cylinder was bypassing, replaced it, and apparantly with the higher pressure now applied to the slave cylinder, it leaked. Replaced the slave, bled the system, it was finally happy. I believe to get at the clutch master cylinder you have to remove the battery and tray. Good luck!
