Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 09-12-2005, 11:00 PM
s2h0a0n6e s2h0a0n6e is offline
Headunit
i am about to install a Jensen VM9410..into my 2003 tiburon i was wondering if hooking these up were the same as a regular headunit...just like a simple wiring harness and will it fit in the same mounting bracket as a cd player should and is there anything special i need...because i have never messed with a flip out screen headunit....thanks alot
Old 09-13-2005, 12:11 AM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: Headunit
youll need a wiring harness thatll connect a jensen HU to a 2003 tiburon...
try and find one thats plug and play...
if not youll find one that has a plug and the rest youll have to wire up to teh head unit wires..
the headunit should come with the mounting stuff, and you can use the stock bolts (should be able to)
tip:
jus dont go blowwing your car's electrical system...
good luck
almost that time
my sig made mommies cry, thats why i had to change it..
Old 09-13-2005, 07:28 AM
yea if its the same way as hooking up a regular headunit that it should be no problem because i have wired up many headunits in cars....thanks man
