Old 09-12-2005, 10:44 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Oil pressure sender location
Anyone know where the sending unit is for the cluster idiot light?
Is it seperate from the sending unit for the pressure gauge?
My idiot light like to flicker sometimes at idle.....for no reason at all. My oil level is fine, it gets changed every 2k along with a new filter and the pressure gauge is right where it has been since I bought the car.
The weird thing is that it only does it at idle.......sometimes
I am praying that it's the sending unit for the light and not the oil pump.
Any ideas?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-13-2005, 11:09 AM
Black97GST Black97GST is offline
Re: Oil pressure sender location
its about haf the size or less than the oil pressure gauge sending unit, it also has a wire connected to the top of it. ill try to find a pic of it for you.
Old 09-13-2005, 10:57 PM
kjewer1 kjewer1 is offline
AF - Advisor
The pressure senders for the oil pressure guage and the idiot light are both on the oil filter housing right next to the drivers side wheel directly under the accessory belts. The one facing the radiator is the idiot light sender, the rearward one facing the firewall is the guage sender.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-13-2005, 11:12 PM
Re: Re: Oil pressure sender location
YEP!
Old 09-14-2005, 07:42 AM
Excellent! That's just what I needed to know, thank you!
1997 Spyder GS-T
5-Speed
