Old 09-12-2005, 09:50 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Anyone else have ACT2600?
Well, coming home from class today, my tranny was unbearable. I pretty much had to slam one gear to the next with all I had. I'm getting used to this though, because it seems like every time it starts to act up like this, it's my slave cylinder. Sure, enough, I ripped it off tonight and it was. I go through probably 4 slave cylinders a year, once every three months, and every time, It's because the boot rips and lets air in the lines. Not to mention, a shift fork every two years. Would anyone attribute this to my clutch? Even after replacing the slave cylinder tonight, and bleeding it completely, my gears are very very knotchy... first and second gear don't like to go in, at least not with some force... some "annoying everyday driver pain in the ass grinding" force. Does anyone who have any insight on how much stress this clutch is actually putting on my tranny(and which parts are affected), and how the hell I can get it to shift smoothly?
I think what i fear I'm getting down to is, do I need a new tranny? Is it possible the synchros are pretty worn, and would BG synchroshift do anything to a tranny that shifts this shitty? Any answers would be greatly appreciated cause I'm really starting to hate driving this car
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 09-12-2005, 10:02 PM
91clipsedude 91clipsedude is offline
Re: Anyone else have ACT2600?
act 2600 is a heavy duty clutch. Had one for 2 years on my 98 gsx. Notice how your left calf muscle is bigger than your right-lol. Not quite sure if that would be your problem but wouldnt put it past it. Its kinda to much clutch for alot of everday driving. Its more of a clutch for drag racing if you ask me. I know driving in seattle traffic with that bad boy set my road rage into overdrive a 2100 would be more forgiving since its a slight step above stock. A tranny flush will usually show any signs of metal shavings and i highly recommend it. Bg and redline are my choice of fluid, but without personnaly driving it I could say if a new tranny is in need. a 2600 with hard driving will shorten its life 4sure.
Old 09-13-2005, 05:07 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
my friend on his 95 tsi awd has put 2 slave cylinders in his car and he has the act2600
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 09-13-2005, 10:46 PM
kjewer1 kjewer1 is offline
AF - Advisor
I've run half a dozen 2600s in the 2g.
The boot tearing has nothing to do with air in the lines. It can lead to a leak at the seal though from abrasives getting in there. Bad forks will break, luckily my second one was good and lasted several years.
I'll list a few causes for notchy tranny besides just being worn.
Not bled properly (many people THINK they know how to do this...)
Bad master
Clutch rod not adjusted properly. Most poeple don't know what this rod is really for...
Rubber clutch line expanding under pressure reducing travel.
Incorrect step cut on the flywheel.
A crappy clutch setup that makes shifting notchy will gradually kill the synchros over time. I could go on for hours about this, there is really a lot of material to cover.
I guess the first question would be have you removed the accumulator and installed a stainless line?
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-13-2005, 11:05 PM
Re: Re: Anyone else have ACT2600?
Bad master
If you ever get bored and feel the need to go on hours about my clutch, or clutches in general, feel free to PM me cause I'd definitely like to know. On another note, I have not installed a stainless line, mainly because I'm unsure of what the "accumulator" is, but if you could give me a slight more detail, I'll be sure to do it.
And if anyone wants to trade straight up, a good 2100, for my 2600, I'd be interested in the offer.
MOD LIST:
Old 09-13-2005, 11:42 PM
AF - Advisor
The accumulator is mounted in front of the tranny, part of the line going to the slave cyindler. Looks like a little canister. The SS line will replace it. I can't remmeber the 1Gs exactly though, hopefully this still applies. I'll try to post again when I have more energy... BUt what was the flywheel step cut to? How is the rod set? Etc.
Kevin Jewer
