Old 09-12-2005, 07:37 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Exclamation LOUD POP from back? WTF!!
This scared the hell out of me last nite, and it did it again today. I was driving, kinda fast, nothing too bad though. The lane I was in was ending, so I jumped on the gas and flew around the guy in the lane that wasn't ending. As I flew by, close to the curb, I heard a LOUD POP from the passengerside rear. I thought I cut a tire. I pull over and look at the tires... nothing. Everything was fine. No holes, no nails or nothing. Drove fine the rest of the nite.
Today I was driving home and I was going fast around a bus. I think I hit a little hole or dip, and I hear that same LOUD POP... exactly the same sound, same place. I have no idea what this can be. The tires are fine. I don't know what it is. I don't want to take it in to the shop. I dont have money right now. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-12-2005, 07:42 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
A pop as in exhaust backfire or possibly an old shock making some noise..My gas shocks in my car make a crap load of noise lol
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-12-2005, 07:46 PM
david-b's Avatar
Dave is THAT guy
Re: LOUD POP from back? WTF!!
It's not backfire. Too loud for it, and only from the passenger side. Wrong side for exhaust. Its LOUD. Somethings wrong. Shocks? How do I test?
75 Monte Carlo
Old 09-12-2005, 07:52 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
with the car parked bounce each corner up and down till you get it really moving then stop and see how many times it keeps bouncing before it stops. shouldnt be more then 3.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 09-12-2005, 09:40 PM
91clipsedude 91clipsedude is offline
you should really be able to tell the difference between even the lightest backfire and suspension noise. If its suspension noise the sound will be god awful in extreme cases. Sometimes just manually bouncing the car wont tell you. Take it over a couple of good speed bumps. That should tell ya if its the shock being blown. Also check the springs. They might not be sittn right.
Old 09-12-2005, 11:46 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Could also be your upper control arm bushing or a bushing broken inspect them also.
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 09-13-2005, 09:28 AM
david-b's Avatar
Dave is THAT guy
it's not backfire at all. I know what that sounds like and it's not it. My car is slightly backfiring every now and then. Its not that thats making the noise though
75 Monte Carlo
Old 09-13-2005, 12:23 PM
Like i said check your bushings mine did that few months ago. Could be your problem
2002 VW Jetta 1.8T
Old 09-13-2005, 03:28 PM
Turbodog97's Avatar
Just a Neon
Does the sound happen at other times besides speeding around somebody...? If its just old and squeking then spray some water on it and that should loosen up some of the dirt/grime and make it a little quieter.
05 Srt4
97 Mx-5
Old 09-13-2005, 03:59 PM
david-b's Avatar
Dave is THAT guy
I only heard it twice. It literally sounds like a tire popped. Loud as all hell. You can hear it clearly over the radio. Kinda like gunfire too, i guess. I havent had time to check it. I did notice though, that when I go over a speed bump slowly and quietly, you can actually hear the shocks compress... hard to explain. Sounds like air coming out, then back into the shock. Are you supposed to be able to hear that? Maybe it is time for some lowering springs, shocks, and camber kit. Grr, no money. Thanks
75 Monte Carlo
Old 09-13-2005, 09:35 PM
Turbodog97's Avatar
Just a Neon
Its time!
05 Srt4
97 Mx-5
Old 09-13-2005, 09:45 PM
Kamilpl3 Kamilpl3 is offline
Send a message via AIM to Kamilpl3
Originally Posted by endlessheart666
Its time!
Old 09-13-2005, 10:48 PM
2002 VW Jetta 1.8T
