Old 09-12-2005, 06:58 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Wtf Mbc?!?!
Alright well lately my ebay mbc has been wackin out or somthng. The lowest I was Ever able to set it was 12psi to be safe with my evoIII but not any lower than that. Since gas has been so high I havent dogged it for about 2 weeks until today and somehow I kept getting 14-15 psi in 3rd gear and 12-14 in 2nd. Wtf? Is it time to upgrade to a better boost controller like a electric one what? My mbc has never given higher numbers before and the screw(on the mbc) is as far as it will go out without falling out. Any ideas would be great. Thanks again!
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-12-2005, 07:05 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: Wtf Mbc?!?!
Are you sure its not boost creep or boost spike? What kind of exhaust are you running?
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 09-12-2005, 07:06 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Wtf Mbc?!?!
My MBC is starting to act up also. Though my car's been in the shop for over a month, when I was driving it around, the boost didnt seem to go up, despite several turns. That, or the boost guage isn't doing it's job, which is much more scary!
I am currently saving up to buy a GReddy Profec B Spec II.
Reason 1= Excellent reviews on functionality, performance and ease of use, per dollar value; both here on the forums and from people at meets.
Reason 2= A comprehensive tuning guide is available, posted by BoostedSpyder, which can be found here:
http://www.automotiveforums.com/vbul...d.php?t=247106
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-12-2005, 07:15 PM
Turbodog97's Avatar
Just a Neon
i have a 3 inch greddy exhaust. I mean I need to be pulling lower numbers like 10-12psi on that turbo. The boost has never spiked before I dont know why it would now...but either way if I bought an electronic boost controller wouldnt it allow me to get 10-12psi either way?
05 Srt4
97 Mx-5
Old 09-12-2005, 07:20 PM
Killa_DSM's Avatar
Re: Wtf Mbc?!?!
Try connecting the line directly to the actuator and see how much boost is produced. Whats the EvoIII GT actuators set at anyways?
Old 09-12-2005, 09:05 PM
91clipsedude 91clipsedude is offline
Re: Wtf Mbc?!?!
if you paid 4.99 for a ebay bc you get what you pay for. I was runnin 263 hp in my 95 gst with evo turbo and a dejon tool mbc. Never had any problems with it. My 98 gsx with a 6bolt again i used a mbc i picked up for 50 bucks. Never had a problem with it. Expensive b\c are over rated and (expensive) for people that arent going for crazy hp. Its very common to get a couple of psi spike with the evo especially if you dont have a evo 02 or ported o2. If those numbers start climbing above 16 psi that might be a problem. In 3rd gear, around 2500-3000k floor it, till about 6-6.5k. If you think its set for 12psi because thats what it reads in 1st and 2nd, i wouldnt worry if it climbs to 14 or 15. Its very common
Old 09-13-2005, 10:59 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Wtf Mbc?!?!
This is always the best thing to do to rule out a bad boost controller... My boost is a little higher now just because the weather up here is a bit colder. I know you are in texas though, not sure if the temp drops down there this soon.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-13-2005, 11:21 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Wtf Mbc?!?!
I think that should be made a sticky some good info there!
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 11-01-2005, 07:31 PM
laser apexi turbo laser apexi turbo is offline
Re: Wtf Mbc?!?!
my friends supra had the same type a prolem with his $2 mbc off ebay. turned out that the instide of the mbc was coroded pretty badly for some reason.
Old 11-01-2005, 08:14 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Wtf Mbc?!?!
Yeah like 95 GSXRacer said the weather probably does play a key role in the turbos that everybody uses, because the air is more dense.
Just a reminder to everybody:
Make sure that your coolant level is up and that it has the correct mixture to not freeze and to cool the engine which is its purpose.
Also make sure that you have the correct oil for the winter.
And last but not least make sure if there is any water in your gas tank, make sure you get most of it out. Wouldn't want anybody's gas lines to freeze up when water runs through them.
Just trying to do my part, I heard that this winter is suppose to be a bastard so do your best to be prepared. Good Luck everybody on the roads, have fun, but play smart.
