Old 09-12-2005, 06:37 PM
95ClipseGS-T 95ClipseGS-T is offline
Send a message via AIM to 95ClipseGS-T Send a message via Yahoo to 95ClipseGS-T
Need S-AFCII Help
ok well im in need of some help with my S-afcII. Ok well the car is running like crap when i got it out the shop and messed with the throttle point settings. My question is, i need to know ABOUT what the low table should look like with my setup. just a ball park figure to what it should be about.
95 GST
5 Speed
Cone Open airfilter
Custom 3" Turbo Intake
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-12-2005, 09:46 PM
91clipsedude 91clipsedude is offline
Re: Need S-AFCII Help
roadraceengineering.com/newafcsetting.htm
hope that helps
Old 09-12-2005, 09:51 PM
2nd note-- every car is different in its own way, use rre's table to give yourself an idea. If their settings work for your application awesome, but some adjusting will probably be needed to get what you like.
Old 09-12-2005, 10:08 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
what rims are those clipse-GST, i think I just found my rims
now - 2000 civic
soon - 2002 is300
Old 09-12-2005, 10:40 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
It depends on a lot of things, PCV valve, O2 sensor condition, etc, etc. As a guideline, you should be about -18% on the SAFC-II on the Lo throttle table (with 550cc injectors).
But to show you how off that can be based on the car, I am around -15% on the lo throttle map and I have 650cc injectors.
On the other hand, I am around -33% on the hi throttle map (Dynoed at 11.3:1 AFR), which is right where I should be.
Just tune for FT's and you will be fine.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-12-2005, 10:51 PM
yea i know thy all diffrent. i just want to get a ball park setup so the guy thats doing my car wont really have to worry abou that. Hes trying to figure out wtf my car is missfireing and giving me p0300 code.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-13-2005, 02:00 AM
^^^ what rims are those man? I gotta know
now - 2000 civic
soon - 2002 is300
Old 09-13-2005, 07:46 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Re: Need S-AFCII Help
Have him run an injector balance test. If he doesn't find anything doing that then try a power balance with spark. P0300 is a random misfire code so there should be a history of which cylinder is misfiring in a scan tool.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 09-13-2005, 01:23 PM
im guessing the injector balance will show if a injector is dirty or something right?. and the spark power balance would show if its a coil or something like that.(ive changed and gaped plugs, plug wires)
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-13-2005, 01:24 PM
they are discountinued, it was 1 of only a few sets made, company went out of buisness before they really got started lol. Im about to sell them if you wanna see about buying them. Let me know and we can work something out.
95 GST
5 Speed
Cone Open airfilter
UICP/LICP
1g BOV
JoeP MBC @ 16psi
2.5 Turbo back
16g
550cc injectors
S-AFCII
PocketLogger
95 GST
Old 09-24-2005, 01:22 AM
17" ? PM me if so
now - 2000 civic
soon - 2002 is300
