Old 05-11-2002, 02:07 AM
GTRsi GTRsi is offline
Send a message via AIM to GTRsi
dum ricer Q Z28 V. SS
ok,
what is the big diff bewteen the '02 ss and z28? I thought they both had ls1 motors? O'well hit me with your domestic knowledge. also could you guys post some links to good Bultin board for camaro's?
thanks
Killer Ninja's are not trained, they are born!
Old 05-11-2002, 03:01 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Depending on the options that an SS is equipped with from SLP, an SS can have 325, 335, or 345 hp from the factory. Z28's are rated at 315 maybe, not quite sure cause I've never driven on or asked about it. Besides the exhaust and intake mods that create the differences in horsepower, the other differences are cosmetic (hood, spoiler, ground effect on rear bumper if center mounted exhaust is ordered, grille, etc.). There are several suspension packages available as well. Hope that helps you a little bit.
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 05-11-2002, 03:19 PM
Seems like alot of cash for such a small diff, however i dont really know how much I/E will run on a v8. I maybe making the jump to 4 extra cyl. will see.
thanks
Old 05-11-2002, 07:22 PM
All of my aftermarket stuff is on the intake and exhaust sides of the engine, and in the sig above. Those in total have come to about $700.00 for the aftermarket stuff on mine. I used to have a 90 Integra, and I'd not go back to a 4 cylinder if my life depended on it. I love my car.
Old 05-12-2002, 10:25 AM
you have any cool borads or websites you could post?
Old 05-12-2002, 11:47 AM
The main ones that I frequent are this board, www.slpeng.com, and a couple of local F-body associations. There's www.camaroz28.com, www.ls1.com, and most other good board you can access through links at this boards.
Old 05-12-2002, 04:55 PM
Blackbird01 Blackbird01 is offline
The performance increase is minimal. Hardly worth the extra money spent. However, I think a SS looks better then a Z28 (from factory) and the "rarity" of them is what most people are interested in.
Also try: www.LS1Tech.com
That sites purely a "technical" board that focus' on Powertrain/Driveline/Suspension aspects of all LS1 powered cars, as well as drag racing/road racing them.
2001 Trans Am WS6 (A4)
Old 05-21-2002, 09:18 AM
twiztidz28's Avatar
twiztidz28 twiztidz28 is offline
Send a message via AIM to twiztidz28
If I still remeber correctly when I went to get my 2000 Camaro SS the SSW package was a litle more then 3k. Well now it is probably more. The package included differnt rims, tires, hood, spoiler, air intake, and SLP dual exhaust. After 2000 the SS rims are ugly and if you wanted to get a LS1 get a 2001 or 2002. there is a bigger LS1 intake. Or you can buy a 98-00 and just upgrade to the bigger LS1 intake for $800 and gain 20 hp. My advised if you are looking to get a Camaro LS1 get a Z28 and put the hood on it($700), SLP loudmouth exhaust($350), FLP Full length headers and y pipe($1,200), Gears if M6 4.11's ($400) if auto 3.73 with a 3,400rpm torque converter($900) you will be running low 12's and look almost the same as an ss with out the wing ($400). That is only if you buy brand new. You can get a 2000 SS for around 20K with pretty low miles on it. Stay with the Dark Blue Metallic, pewter, or the Burgandy. You don't see many of those. Also if its 2002 get the sunset orange an awesome color. Hope that helped.
Chuck
86Z28, NEW 383 w/ 671 GMC blower, 6 point roll cage, spohn subframe conectors, turbo400 bulit proof trans, with Auborn 3.73 posi. ( past mods 350 gm motor, Borg Warner 5 speed, hurst shifter, Edelbrock heads and carb, Edelbrock headers and cat back 3" all the way,) 2 1/2" cowl induction hood.
"The name for the car says it all twiztid Z28" Check out the 86 Z28
Old 05-29-2002, 09:30 PM
The DeViL The DeViL is offline
Why would he want a y pipe aren't x pipes better for performance?
A standard Camaro SS from Chevrolet is 325 hp and it's Ram Air inducted. Not to mention has superior handling then the Z28.
A standard Camaro Z28 has 310 hp, no Ram Air.
Look at it this way...
SS = More power, better handling
Z28 = Less power, not as good handling, but still not bad.
Old 05-30-2002, 08:21 AM
twiztidz28's Avatar
Devil,
The SS does not have better handeling then the Z28, you can get the 1LE package with is bigger upper and lower control arms and sway bars if i remember correct. That is the only preformance handeling package Chevy offers for the Camaro and Firebird/Trans Am. And the reason for the Y pipe is the LS1 F-bodies are single cat cars. So you can not use a X-pipe. If you buying from the dealer the SS is not worth it. You can not tell the difference in the 15 HP from the factory. Better off getting a Z28 unless you can get a SS for the same price
Chuck
Old 05-30-2002, 02:02 PM
.I guess so but thats something you have to order on extra to the Z28. Stock for stock the SS has the better handling, although with the package I'm guessing its still cheaper then buying an SS?
Well that about wraps it up for that question
Ram Air helps in the long run but hell, why not just buy it as an add on for a Z28?
Old 06-03-2002, 07:05 PM
Alright, lemme chime in on a few discrepancies I noticed.
Looking at it performance wise, there is a very MINIMAL, if ANY performance gain to be seen between the SS and Z28. Most people that plan on MODDING their LS1's prefer Z28's as they are not only cheaper, but are also typically lighter.
The reason LS1 owners opt for a new Y-Pipe is because the left bank side of the stock Y-Pipe is very narrow and the entire unit flows poorly.
Fitting an X-Pipe under them is difficult and must be done custom, leaving very little ground clearance. Most hardcore drag racers choose to go this route (I am also looking into a TRUE dual exhaust with X-Pipe setup), as it typically gives slightly more power. Just to correct something that was said earlier, the LS1 cars, and late LT1 cars are equipped with 2 catilytic converters. Only the early year LT1 cars had the single cat.
