can anyone tell me where the fuel pump resistor is located on a 2000 GTP
Re: fuel pump resistor
http://rmcgp.clubgp.com/fpresistor.html ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
thanks for the input. Found it and fixed. Runs like it should now.
thanks for the info. Found it and it runs again.
Re: Re: fuel pump resistor
Here's another link with a better illustration:
http://www.pfyc.com/store/merchant.m...y_Code=RGUNDER Its applicable to '97 to '00 GTPs only. From '01 and up to '03 it was moved to the rear of the vehicle someplace by the fuel tank. ![]() ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph
Are you supposed to jump the speed control relay or the pump relay because #14 on my 99 gtp is the pump relay and #15 is speed control. ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.[/quote] |
Click here This is a very old thread so I am closing it.
