Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-12-2005, 03:25 PM
drifter1283 drifter1283 is offline
Question Question?
Hey guys I just bought a few aftermarket parts for my 90' 240 and all the intallation instruction are for JDM egines that come in it I cant figure out how to install it on my ka24de. here are is a list or the parts i bought HKS SLD, HKS FCD, I also bought an A'pexi S-afc II, have any of you guys installed these on your car? I havent been able to find an helpfull ecu pin out.if you guys can help me that would be great if not do you think i should just take it in to be installerd in a shop? and if so so any of you know of any shops that can do it near Seattle WA?
Old 09-12-2005, 04:24 PM
D-Bo's Avatar
D-Bo D-Bo is offline
Re: Question?
take it to a shop. if you don't know of one then look in the phone book.
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 09-12-2005, 04:26 PM
orestes's Avatar
orestes orestes is offline
would that all even work on a KA if it was for an SR?
"I got that hustle in my genes like high blood pressure" -E-40
Old 09-12-2005, 04:41 PM
it should work all i have to do is find the pin out or a wiring diagrahm
Old 09-12-2005, 04:43 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Question?
You have a 1990 with a KA24DE? And I'm guessing your engine is otherwise stock, why would you need these electronics?
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 09-12-2005, 04:52 PM
errmmm :x i just called up a local shop 60 for the hks fcd 60 for the hks sld and 120 for the apexi S-AFCII. i also asked them about my IACV they said they said 400 for the install :X they are trying to rip all the money i dont have away from me!
Old 09-12-2005, 04:56 PM
well i have an intake exhaust manifold and and a cat-back exhaust. and my car car was running a little rough on decel and two i hate maxing out at 115. and three prety soon I should have either a ka-t or and rb20 havent decided yet. I also just moved to Washington so I have to try and legalize my car and have it pass smog, its going to be a huge head ache!
Old 09-13-2005, 03:59 AM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
Re: Question?
unless you can read wiring diagrams really good...or decent i wouldnt do your own wiring...you can really screw a car up F'ing with it...i Personally would take it to a shop to...NissanFanatic should be able to give you the wiring on the SAFC II though...Nissan where ya at?
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 09-13-2005, 05:27 PM
i can read them just fine i did the swap on my car it wasnt very hard ( sohc to dohc) alot of it was just match the colores =\ but im more than capable i just dont have the all the info to do it.
Old 09-16-2005, 11:53 AM
Re: Question?
well i put the S-AFC II in and the HKS sld, but i wasn't able to put in the FCD ( the only one i bought used) it seemed to be missing a wire so i didnt want to mess with it other than than they work fine. thanks Nissan for the pinouts
Old 09-17-2005, 12:53 PM
robunicu robunicu is offline
Send a message via MSN to robunicu Send a message via Yahoo to robunicu
Re: Question?
The stuff i dont know how to play with, i just take it to the shop and know that they did it right and its not gonna fk up my car...it more safe i think...but whatever floats your boat
Re: Question?
Old 09-17-2005, 01:52 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: Question?
why would you need a fcd on a non turbo engine
RX-7 TII
Old 09-18-2005, 12:28 PM
my ECU limits the speed on my in two way via a speed siganal that is sent at a certain speed and when it reaches a certain RPM which then cut the fuel being fed to the car = get a FCD and then get a SLD its been talked about in the forums before , im pretty sure you need both to be able to go over the ECU speed limit. I got it for cheap and i just figured out that i read the intructions wrong so im going to put it in monday.
Old 09-18-2005, 01:55 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
Re: Question?
why don't u just install the auto KAe4de ECU instead of your manual ECU, you will have no speed limit!!!
what your doing is a waste of money! u want 2 go past 120 mph but u have a stock car?! w blown sub frame bushing...etc? i hope your car suspension is fixed up and your breaks are up 2 the task of slowing you down at that high speed...
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car"
E.K.
