Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 09-12-2005, 02:51 PM
bourneville5304 bourneville5304 is offline
Send a message via ICQ to bourneville5304 Send a message via AIM to bourneville5304 Send a message via Yahoo to bourneville5304
Angry 98 concorde LXI starting problems
Ok so my wife apparently didn't think it was important when the speedo quit working a couple days ago well then it apparently got "a little warm" then i seen her out today and it was HOT so i had her to pull over and turn it off well now it won't start and the battery is low i jumped it and got it turning over good but still no start, it tries, sounds like it's firing but,.? there is no sign of water under the car and not alot of oil, (there is a little but i think it was already leaking a little) if anyone knows where to start please let me know thanks,
Old 09-12-2005, 07:04 PM
Bizzy102 Bizzy102 is offline
Re: 98 concorde LXI starting problems
try your crank sensor. Sounds like its not working.
Old 09-12-2005, 09:42 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
I hope you didn't get the engine so hot that you've warped a cylinder head. That is very possible in addition to a blown head gasket if it ran hot. Either scenario is pricey and will cause a no-start and with aluminum cylinder heads, it doesn't take much to warp them.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-13-2005, 08:00 AM
thanks guys i'll check that stuff, P.S. got it running and now it's idling really rough and won't hold charge if i hook it up to another car through jumper cables then it seems to run fine should i try the alternator?
