Go Back   Automotive Forums Car Chat > Volkswagen > Golf
Old 09-12-2005, 02:18 PM
pietru pietru is offline
95 golf 2.0 -> black smoke, erratic idle
Hi everyone, I am new to this forum and from what I have seen it looks great.
I wonder if anyone can help me out.
I have a 95 GOLF 2.0L. The first time I start it on a new day I get a lot of black smoke coming out and the idle is not steady. If I put it in 1st gear and try to drive, it will stall. I need to let it run for a couple of minutes to let the engine run smoother, and then I can go. I will still need to give it more gaz then usually to start on a stop without stalling tough.
God you should see the black smore cloud that this problem creates, awfull.
This morning I started it to put it on ramps because I want to change the gaz filter to see if it helps but I didn't let it run long enough, it stalled and now it won't start. Maybe I flooded it but anyway....
Anyone has an idea?
Old 09-13-2005, 09:04 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like maybe a bad maf sensor, but the check engine light would be on.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-14-2005, 08:30 PM
boschmann boschmann is offline
Re: 95 golf 2.0 -> black smoke, erratic idle
Check out threads on coolant temp sensor.
Old 10-14-2005, 08:01 AM
Kashan Kashan is offline
Hi mate,
I am having a similar problem on a 2.0l 8v mk3 engine transplanted in my mk2 gti shell.. thats some crazy black smoke bruv.. did you have any luck sorting it out though? I'd really appreciate any light u could shed on the situation.
cheers
Kashan
Anyone has an idea?
Old 10-14-2005, 08:10 AM
Re: Re: 95 golf 2.0 -> black smoke, erratic idle
Kashan I just replaced the mass air flow sensor.
IT DIDN'T HELP!!!
I still have the same problem. The car is unusable.
I took it for a 5 mins ride and kept stalling at stop signs. When I got back I decided to check oil and noticed smoke coming out the oil guage, well not the guage but where the guage is stored.
I bought a used mass air flow system. Could it be defective too? I doubt it.
