Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-12-2005, 12:48 PM
chrisz17 chrisz17 is offline
1999 Tahoe A/C Clutch won't engage
Is there a way to test the electronics in the pump and wiring harness to see if I have a signal problem before I assume the clutch is burned out?
Old 09-15-2005, 05:37 PM
TGARST TGARST is offline
Apply 12volts from the battery to the connection on the compessor clutch. if it clicks clutch is probally good. did you check freon charge/ pressure switch?
