Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 09-12-2005, 08:32 AM
BAMBAM1972 BAMBAM1972 is offline
1998 Won't start
At 160,000 I had my motor replaced in my ZX2 with the same year motor from a reputable salvage yard. The used one had 45,000 miles on it. 13,000 miles later (173,000 on the car, approximately 58,000 on the motor) I had a couple of days where when I started the car it would run rough for a minute or so and finally smooth out. After about two days of this it only started by pumping the gas and flooring it for about 5 seconds then I made it home where when I cut it off it won't do anything but turn over now. I changed the fuel filter, still will not start. I am not a mechanic but have a little common sense if anyone can help point me in the right direction. It is a 5 speed, and I hear the fuel pump when I turn the ignition key on. I located the fuel pump driver module but how would you test it or should I be looking somewhere else. Any help would be appreciated.
Thanks,
Allen
Old 09-20-2005, 06:05 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 1998 Won't start
Sounds like it is overfueling on cold start. Did you look at the plugs and see if they are fuel saturated? I bet they are.
Possible causes if so are are bad fuel pressure regulator, coolant temp sensor, intake air temp sensor.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-21-2005, 06:36 AM
I first check the resistance in the wires and it seemed fine. Then $11 and four new plugs later fixed the problem and they were fuel saturated as you said. I have driven it for a week and pulled one of the plugs which seems to still be fine but now there is a bucking especially when starting from another gear other than 1st. It is almost as if it is not getting enough fuel then other times it will run perfect.
