could this be it??
I had some front end work done on my car. I was hit in a parking lot and had the front bumper replaced, grill, hood and top bar going accross the top of the radiator. And i believe i had to have the frame be pulled....could this contribute to the leaking of coolant??
Re: could this be it??
possibly.....did you replace the hoses, or at least check them to see if they were damaged??
i would have the system pressure tested. that will tell you where the leak is coming from. if the damage was enough to have to pull/replace the radiator support....the accident may have cracked the radiator. i would also have your condensor checked out for leaks as well....if it wasn't replaced.
