1992 Fifth Avenue will not start.
1992 New Yorker Fifth Avenue will not start at all. Everything has been replaced that normally causes this trouble.
The mechanic says that for some reason the signal isn't getting from the crank sensor to ignite the fuel and apparently he doesn't know what to do to fix it. Both fuel pump and crank sensor are new. Any thoughts on how to correct the problem??? Thanks |
Re: 1992 Fifth Avenue will not start.
Have him check the ASD (AutoShutDown) relay. It controls power to the coil pack and fuel pump. Chances are your relay is tripped or busted and needs to be replaced.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
Thanks for the advice. Of all the explaniations I've heard and tried thats a new one. I'll post back if it's the trouble.
Meanwhile, anyone else feel free to add their own thoughts. Thanks again
Re: Re: 1992 Fifth Avenue will not start.
Thanks
The ASD is located inside the drivers fender next to the sbec. You may want to have the SBEC and the body controller checked. Both will kill the vehicle
If you set the alarm of it will shut down the engine & won't start. try unhooking the battery for 5 min"s to reset it then unlock the passengerside dore with the to reset it. or maybe u got a dead battery.
