Go Back   Automotive Forums Car Chat > Honda > Insight
Old 09-11-2005, 11:44 PM
Rory_W Rory_W is offline
2001 Insight P1259 Trouble Code
While driving my car engine started to die and then the check engine light came on. Car started to drive fine, but when checked to see trouble codes, I had a P1259 VTEC code malfunction. I'm assuming P1259 is a VTEC code on the Insight. My freeze frame data is as follows.
Fuel Sys1: Open Loop Driving
Calculated Load: 50%
Coolant Temp: 197.6 deg F
Short Term FT,B1:0.0%
Long Term FT,B1: 0.0%
Manifold Absolute Pressure: 14.8inHg
Engine RPM: 4625RPM
Speed: 53.1MPH
Intake Air Temp: 116.6Deg F
Throttle Position: 24.3%
Any help will be appreciated.
Old 11-20-2005, 09:21 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 2001 Insight P1259 Trouble Code
check for open and shorts between ecu and vtec switch. test the vtec solenoid and switches for voltage contiuty, resistance.
if you dont understand, a haynes from your local parts store will have the diagrams and explanations in them for you.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 12-03-2005, 03:10 PM
lorunner lorunner is offline
Check the oil make sure you have it in the engine.
Stop asking me about radio codes I cant get them anymore!!!
