Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 09-11-2005, 11:46 PM
xqqme2day xqqme2day is offline
Send a message via Yahoo to xqqme2day
Gas Cap Door
The cable from the release lever and the catch in the filler cap area issticking - leaving the door either open - or closed. When closed, the emergency release won't even work.
Anybody else had problems? Is there a way to remove the cable and lube it? And how about the emergency release - what's up there? Thoughts?
'97 Concorde LXI
Old 10-23-2005, 06:17 PM
Sea Cliff Wizard Sea Cliff Wizard is offline
Re: Gas Cap Door
You have to replace the cable. This is a little sticky (pun), it involves removing trim and lifting carpet. If the cable is jammed, using the emergency release will not work, you have to disconnect the cable at the door latch.
