Old 09-11-2005, 09:52 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
crank walk
i was just wondering what are the first signs of c/w my car is not running right now but the clutch is kinda sticking to the floor. So i was just wondering if i need to be worried or is the clutch just going out any help would be great. That would suck since i just put the new turbo on. havent even got to test it yet..
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 09-11-2005, 10:53 PM
91clipsedude 91clipsedude is offline
Re: crank walk
sounds like it maybe. improper or inconsistent clutch engagagement, if its difficult to shift and clutch pedal sticking in the down position, those all tell tale signs of the dreaded crankwalk. Thrust bearing failure can happen on all years but are more common on late 95-mid 97. If it becomes significant, the crank movement will start to interfer with the (cas) or crank angle sensor which will, in the end destroy it. Time to get a 6 bolt bottom end!!
Old 09-11-2005, 10:54 PM
Re: crank walk
b4 you worry to much though, flush out tranny fluid and get yourself some redline fluid. Might help
Old 09-11-2005, 11:07 PM
n8s95gsx n8s95gsx is offline
Re: crank walk
tell me if you hear a faint clicking noise when the clutch is depressed... the noise will be heard on the right side of your engine bay
95 GSX 5SP
One of the many victims of CrankWalk
rebuilt motor from xtream motorsports of appleton
Balance shaft eliminator,manual boost gauge (15) OBX BG,OBX air/fuel,hard pipe and filter
dejon intercooler pipes with first gen bov
front strutt bar, 3" down pipe with cat eliminator, and custom cat-back from local shop.
ect...
Old 09-11-2005, 11:14 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Sticky clutch is one symptom. Don't jump to conclusions. Have the clutch checked out first, just so you can eliminate that. There was an audio file of what crankwalk sounded like somewhere on here, try searching for it. The sound is almost like a loose exhaust rattling around. After you have the clutch checked out, then we can start digging into the guts.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-11-2005, 11:28 PM
Re: crank walk
Crank walk will usually not make a noise in the beginning stages of it. It is a slow painful process (USUALLY). Depends on how the car is driven. how long has it been since the car ran last, also you have checked the fluid level right? If the car has been sitting for a while that could have something to do with it unless it did the same thing when it ran. You'll be amazed what a system flush will do to a clutch\tranny. When you get it running, at a stop put it in 3rd and let off. If it dies your clutch is probably alright, if it lunges and jolts like the first time learning to drive a stick, clutch is going bad. You'll know the difference between a bad clutch and c\w.
Old 09-12-2005, 09:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: crank walk
It is not crankwalk until the measured crank end play is over .009 inches. Anything else is just a guess. Of all the motors I crankwalked not one of them had any of the "tell tale clutch symtoms" The only one that ticked was the one that took out the crank sensor, and it only ticked for about 2 days before it would no longer run. And its not just a little ticking like the lifters, its the crank trigger plate smashing the fuck out of the crank angle sensor. It's pretty obvious...
Measure the crank end play and be done with it. I've posted about it before, I am sure it is stickied here somewhere, or at least a link to what I posted at www.racingknowledge.org.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-12-2005, 11:12 AM
Re: Re: crank walk
I havent driven the car in over a week. Its has been kind of hard to get into 1st but once the car has been on for a while then there are no problems just at first. I'll be able to tell you i hope tommorrow if there is a noise comming from the right side. Thats is when the ss oil line will be here.. The car was driven by an older women up until febuary of last year. I don't drive hard very often. So after it warms up for 10 mins or so ill go out for a drive and see what the new turbo can do. Pray its not c/w
MODS
