Old 09-11-2005, 09:26 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
clutch
Hey i have a 97 cavalier rs 2.2 it has about 112,000 on it and i think it is the original clutch. How long does a clutch usaly last? and also when replacing the clutch do you have to replace the flywheel?? Also do they make thoes performance chips for cavaliers like the ones that hypertec make? lastly what is a good web site for cavalier performance parts?
Old 09-11-2005, 10:40 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
heres a very good list of websites that carry cavalier performance and appearance parts, sorry its all of your question that i can answer
http://www.automotiveforums.com/vbul...d.php?t=405722
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 09-12-2005, 12:36 PM
cdru's Avatar
cdru cdru is offline
Re: clutch
How long a clutch lasts really depends on how you drive. If you shift properly they can last for a very long time. If you ride the clutch a lot, shift improperly, use it in competitions, etc then you can go through one fairly quickly. I'd say 112,000 it's more then possible that your clutch is wearing out. What are your symptoms that make you think it's your clutch?
As to what you will replace, you will need to buy a clutch kit. It will come with a new cluch, pressure plate, and usually a installtion tool for alignment. You most likely won't have to purchase a new flywheel. You will however have to resurface your flywheel. The flywheel is much like brake rotors. You want to start with as perfect of surface as you can for your new clutch. If you don't resurface it, any imperfections such as groves, warpage, glazed over spots, etc will quickly damage your new clutch. The machine shop that resurfaces it will be able to tell you if it can be safely resurfaced/reused. If it can't be (too badly damaged, too thin, etc) then you will need to buy a new flywheel.
You'll also want to pick up some brake cleaner to wash everything down as well as some break fluid to flush the system while you are at it.
Vinyl adds horsepower, right?
Old 09-12-2005, 04:06 PM
97cavalier's Avatar
Re: clutch
Well i don't think it is really going out i was just wondering how long they last. Only thing that i would think it is going out is if i start off in first gear and get a high rpm and trie to pop the clutch for second gear scratch, for one it don't do it and two it jearks a little and starts at a low rpm. So i am think about replacing it with a high performance clutch any ways. And get a light weight flywheele just to be safe.
