Old 09-11-2005, 07:13 PM
smjnw smjnw is offline
Water pump replacement?
I have a 98 honda accord 4 cylinder. The coolant is leaked at lacation of water pump's gasket area and the pipe.
For the gasket replacement, the water pump needs to remove? If so, the timing belt needs to remove too?
Thanks for help,
Old 09-11-2005, 10:50 PM
mpumas mpumas is offline
Re: Water pump replacement?
I think the water pump is behind the timing belt cover and is driven by the timing belt. So ya, everything needs to come off and you should change the belt is you are in there and are getting close to the magic 90-105 K mark.
Old 09-12-2005, 07:59 AM
jeddi20 jeddi20 is offline
the water pump is connected via timing belts. if you take it to honda the have a "deal". water pump, t-belts, gaskets and hoses for about $600. i had mine done with my tax return money. and it killed it all
Old 09-12-2005, 09:05 AM
Re: Re: Water pump replacement?
Thank you for the help.
