Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-11-2005, 06:02 PM
Cali_Regal Cali_Regal is offline
94 Regal takes long to start, struggles when gassed
I have a 94 Regal Custom coupe (3800 engine). I recently got a major tune up that included changing the ignition wires. The fuel filter was just replaced too. The problem I'm having is, when the car is cold, it takes about 10-20 seconds for it to start when I turn the ignition. When the car is warm and then turned off, it will turn back on right away when I turn the key (just as long as the car is still warm).
Sometimes when I am on the freeway, when I press the gas pedal with a certain amount of force, you can feel the car jerk a little as if the gas isn't continuiously flowing properly. More like it is flowing in "spurts". The take off is VERY slow. When I hit the freeway, I have to stay in the slow lane for about 10 seconds until my car gets up to the speed limit, then I can merge into the faster lanes. If I am heavy on the gas trying to speed up, the car will shut off.
Anybody have suggestions?
Old 09-11-2005, 07:26 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 94 Regal takes long to start, struggles when gassed
Two possibilities, fuel pressure regulator or fuel pump. Change the fuel pressure regulator first, it is much cheaper than a fuel pump a lot easier too. If that does not cure the problem then the fuel pump may be bad. You can check the fuel pump and regulator with a fuel pressure guage, just connect it to the shrader fitting on the fuel rail. Pressure should be in the 45 to 55 psi range at idle.
Old 09-19-2005, 09:38 AM
bearcat5 bearcat5 is offline
You also need to check your fuel filter. A cloged filter will also starve you car of fuel. If you do put a fuel gauge on the rail, pull the vacumn off the reg. and notice if the reading fluxuates. It should about 10 to 15 lbs.
