Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 09-11-2005, 05:59 PM
james wright james wright is offline
Question Hard Start
1998 Express conversion van 350ci fuel injected. Replaced plugs Cap and rotor. Must crank for what seems like an eternity before it fires. Runs great after it starts. Has a new fuel pump and filter. Symptom started shortly after fuel pump replaced.Noticed that fuel gauge is ossilating when cranking or driving. The cap and rotor were bad had corrision but did not solve problem. Did notice that after replacement of cap and rotor did get a backfire in intake twice none since. Woried that I will eventualy burn starter out from having to crank it for so long. Has central secuentual fuel injection. Any suggestions?
Old 09-12-2005, 01:19 PM
RNRea RNRea is offline
Re: Hard Start
Check your basic timing on the ignition.
Old 09-14-2005, 08:18 PM
Re: Hard Start
How do I do that simlar to old style do I use a timming light?
Old 02-12-2009, 01:18 PM
Tanya Marie Tanya Marie is offline
Re: Hard Start
Did you ever figure out what was wrong with your van? My van is doing the exact same thing. It can take anywhere from 1-30 minutes to get it started. The colder it is, the worse it gets. Runs like a top once it's started. The fuel gauge needle vibrates, etc.....Someone said I might need to replace the fuel injector system for $1000+ but I don't want to spend the $ when they aren't 100% sure that's the problem.
Old 02-12-2009, 05:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Hard Start
Welcome to AF.
Always check the date on a post before posting back to it if it is old leave it old do not post back to.
With a problem on you own van start a New thread/post.
The New post button is upper right of forum.
On a hard start cold problem always run fuel pressure test and post back pressure in you New thread.
And some one will help you.
Good luck
MT
Old 12-29-2009, 08:14 AM
68ragtop 68ragtop is offline
Re: Hard Start
I have a 2000 Express that has been hard to start for a few years. Cranks probably 3-4 times longer than it should, once it fires, It runs perfect & usually will refire right away when warm, but when it sits more than 4-6 hours, same thing happens. Its been tuned up several times over the years & this has been going on for at least 35,000 miles. Just went through the 3rd starter this past summer thanks to all the excessive cranking. No codes ever.
Did anyone else here find a resolution to their problem?
__________________________________________________ _______________________
Yes, I know this is an old post, but adding to it, should trigger a message to those memebers posting above & help draw some conclusions now & for future people using the search option? I noticed many members are told not to add to old posts, but whats the point of them even being there if they can't be used for collective information?
Old 12-29-2009, 08:26 AM
MT-2500's Avatar
AF - Advisor
Re: Hard Start
This post is ABOUT 5 YEARS OLD.
Let old sleeping or dead dogs sleep and lie in piece.
Start a new thread/post on your problem and some one will help you.
MT
Old 12-29-2009, 08:50 AM
Re: Hard Start
You should then get rid of the "search" feature. It would serve no purpose correct?
Old 12-29-2009, 10:47 AM
MT-2500's Avatar
AF - Advisor
Re: Hard Start
Search feature is for looking at old post with same problem.
Forum rules say not to answer old post.
Review the forurm rules.
MT
Old 12-29-2009, 11:00 AM
MT-2500's Avatar
AF - Advisor
Re: Hard Start
I have nothing to do with running the operation.
Just trying to steer you in the right direction.
That is up to mods. and administrator.
Here is a link to forum rules.
Take a look and read them and you will see.
http://www.automotiveforums.com/vbul...d.php?t=623321
MT
Old 03-02-2010, 09:37 AM
Kmdon8 Kmdon8 is offline
Smile Re: Hard Start
My van just wouldn't start when the engine was cold. Once it was started using starting fluid it ran great for the rest of the day, including restarting throughout the day. The fuel pump relay has proved to be the problem. Swapped the starter relay with fuel pump relay and it started right up.
