Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-11-2005, 05:10 PM
Maglude Maglude is offline
Electrical problem in dash
Alright, so a weird thing happens randomly in my lude. Starting is fine, mechanically perfect, runs normal. After about 20 minutes or so of driving, the speedometer and tech will start to drop to 0, the fuel/temp reading will flicker on/off and the clock will go dark. It happens moreso when it's at idle, but it will do it when it's running at any speed too, just not as much. Also, when the headlights are on and AC is running, the problem gets really bad, it happens constantly when they're running. Less if say the headlights are on and not the AC, or visa versa.
I got the alternator and battery checked; both are fine. He told me to clean off the positive and negative terminals, the connecters to the battery too. I did that, they're pretty clean now. The problem still exists. Not sure what to do now, the alternator is charging at 14 volts if the number matters.. he said that's fine.
Old 09-12-2005, 09:43 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: Electrical problem in dash
Check that serpentine belt again (the belt that loops around your alternator, power steering, and.. gah I have forgotten the third). Specifically check the tension and the grooves, they probably are slipping.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 09-12-2005, 11:23 AM
thelosman thelosman is offline
You May have a hot wire under the dash that is grounding, unfortunatly this could be very hard to find.
Old 09-12-2005, 12:36 PM
Yeah, well it started to happen a little bit after I got an alarm put it. I'm probably gonna take it back to those guys and tell them whats happening. I had to go back once before because the alarm when on the fritz one day, the owner said sorry because they installed it very sloppy. So it's probably their problem.
Old 09-12-2005, 07:00 PM
joellthomas joellthomas is offline
May be a ground wire, but probalby from that alarm install.
