I have just installed a replacement engine (D15B7) with another D15B7 (from a 94 civic) in my 93 Civic. My problem is that the tranny will not mount correctly because the torque converter will not install all the way on the input shaft. When I remove the converter the transmission will install just fine. Does anyone have any ideas as to why the torque converter will not reinstall on the input shaft properly?? Any help would be appreciated! Thanks!
Check for damage on the shaft/converter. Or corrosion. Sometimes those are hard to get seated all the way, and you have to kinda wiggle it back and forth as you push. But DONT try to thread a bolt and put the trans and block together by tightening the bolt, you'll break something.
Re: Torque Converter Install Question
try and try again till it goes in. its not easy.
99 [email protected] psi si- I voted for the Terminator for Gov. 95 HB- B16a2- SC34@12psi WTB: USDM B16a2 or B16a3 complete short block. pm is the key. FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me. |
twist, push, twist push, twist, push.... it can take damn near forever, but eventually it'll just slip on.
Honda Enthusiast
Do NOT hit it to get it in all the way, that can screw up splines, the converter or the input shaft.
