Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-11-2005, 02:47 PM
Jeff128 Jeff128 is offline
Unhappy Car wont start
I just purchased a 97 Eagle Talon Tsi Awd from a private seller and 10 minutes down the road the car started to lose power. Before i could procede to pull the car over to check tempature and coolant level, the car shut off. I then checked the coolant level and temperature and there was close to no coolant in the tank and the temperature needle was at all the way hot. As a result of this the gas pedal has become stiff and can no longer be pressed down and car wont start after letting engine cool and adding coolant. I then had the previous owner tow it the shop where it was last serviced at. This occured Wednesday and it now being saturday they still havent diagnosed the problem and probably wont be "looked at" until monday. Could you please give me some light on this very dark situation. The wait to find out what is that matter is almost unbearable.
thank you very much,
jeff
