Old 09-11-2005, 02:43 PM
Jeff128 Jeff128 is offline
Unhappy Car wont start
I just purchased a 97 Eagle Talon Tsi Awd from a private seller and 10 minutes down the road the car started to lose power. Before i could procede to pull the car over to check tempature and coolant level, the car shut off. I then checked the coolant level and temperature and there was close to no coolant in the tank and the temperature needle was at all the way hot. As a result of this the gas pedal has become stiff and can no longer be pressed down and car wont start after letting engine cool and adding coolant. I then had the previous owner tow it the shop where it was last serviced at. This occured Wednesday and it now being saturday they still havent diagnosed the problem and probably wont be "looked at" until monday. Could you please give me some light on this very dark situation. The wait to find out what is that matter is almost unbearable.
thank you very much,
jeff
Old 09-11-2005, 05:18 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Re: Car wont start
i feel your pain but i dont see how the gas pedal will get stuck from overheating. Does the engine still turn when you turn the key? In either case though if you can still turn the engine at the harmonic balance, it cant be too bad. If not, worst case scenerio, the head gasket could be gone along with the head.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
