my car is compleatly shut down 91 camaro rs dow do i bypass the vats i cant fnd the decoder module
Re: vats system
how do i bypass vats system on 91 camaro
Re: Re: vats system
"Measure the resistance of the pellet in your ignition key with a digital ohm meter.Then go to an electronics store like radio shack and buy a matching resistor from them make sure you ohm it also. Go under the column and find the 2 little white wires, they are quite small compared to the other wires under the dash. Solder the resistor between the 2 white wires and you should be good to go. Tape the connection up real well with electrical tape." http://www.directechs.com/techtips/p...htips/1049.pdf
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
