Old 09-11-2005, 10:58 AM
chuckwi11 chuckwi11 is offline
20in Tire Pressure
I just "upgraded" my trucks wheels/tires with a set of Silverado SS Powder coated 20in wheels with Eagle LS P275/55R20. The installer set the tire pressure at 35psi and I was wondering what pressure that the SS calls for and what other 20in wheel owners set their tire pressure at??? Thanks in advance.
The tires/wheels look really great and I can update my photos if anyone is interested.
2003 Chevy Silverado
2004 Bonneville GXP
http://members.cardomain.com/chuckwi11
Old 09-11-2005, 11:33 AM
nineball481's Avatar
nineball481 nineball481 is offline
Re: 20in Tire Pressure
ya, let's see em.
I would put in what ever pressure is stated on the tire's sidewall.
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 09-11-2005, 11:41 AM
jethro_3's Avatar
jethro_3 jethro_3 is offline
My wheels are the same set up as an SS. My rims are the factory 20" x 8.5" with the P275/55/R20 Goodyear Eagle LS tires. The tag in the door says 30 psi COLD and the load, passenger and payload, is 1250 #'s.
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 09-11-2005, 12:31 PM
White Lightening's Avatar
White Lightening White Lightening is offline
Re: Re: 20in Tire Pressure
Sidewall pressures are MAXIMUM pressure levels that are not to be exceeeded even under heavy payloads - and have nothing to do with driving pressure levels.
The label in the truck is what is the engineered preferred pressure levels.
On 20 inch wheels with Goodyear Eagle street tires on an ext. cab 1500 - the preferred pressure level is 30 pounds pressure cold both front and rear. The MAXIMUM air pressure the tires should ever have under any load circumstances is 36 pounds cold.
When I got my truck - the dealership had 35 in each tire - while the truck label said 30. When I reset the levels to 30 - it was a substantial improvement in smoothness and handling.
P.S. Nineball - I think your tire/wheel combination is very attractive on your truck.
White Lightening
Old 09-11-2005, 12:44 PM
Re: Re: Re: 20in Tire Pressure
White Lightening
You learn something new everyday.
Thanks for the compliment as well. You made my truck blush
  • Hypertech PP III
-Nineball
Old 09-11-2005, 02:51 PM
jethro_3's Avatar
Nineball,
If I still had the old body I would hunt that truck down and comendeer that hood, then the tires....
White Lightening,
Did you see any difference in your MPG when you changed????
Cam in and
Check out my Ride
Old 09-11-2005, 02:54 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
My 275/40/20's say max psi 44, the people at discount fill em to around 35-37, but that's not stiff enough of a feel for me so i fill them to around 40-42.
*Under Construction - New sig to debut*
Old 09-11-2005, 06:37 PM
Originally Posted by jethro_3
White Lightening,
No. It was something I looked for. The story goes back just a bit. When I test drove a Limited Appearance package truck - it had been very very very smooth. Then the truck I bought - also on the test drive - again very smooth. Both test drives included rough washboard type roads of course
But then on the long drive home from the dealership (about 120 miles) - it just seemed "not so smooth". A couple days in town driving and I then started checking the air pressures. I noted no MPG negatives by reducing the pressures - but an instant change in smoothness, responsiveness, and comfort (all to the positive). Also did not notice any difference in turning resistance (like in parking lots etc.).
P.S. Hey Jethro - when are you going to start showing more Sleeper pictures in that gallery
White Lightening.
. . .>>>>> . .White Lightening . .<<<<<
More pictures???
Link below shows them & a list of features and options on this 2wd SS
V.H.O.
http://files.automotiveforums.com/ga...ite+Lightening
Old 09-11-2005, 07:00 PM
jethro_3's Avatar
White Lightening.
I have been trying for the last 2 days and for some reason I can't get them posted....
Cam in and
Check out my Ride
