Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 09-11-2005, 03:55 AM
jmdcool76 jmdcool76 is offline
fiero stalls
i have a 85 fiero gt 6cyl. and for the last few weeks for some odd reason i've been having to jump start it every couple of days but when i do jump start it it starts right up i have a new alternator and starter but could it be the ignition coil also lately when i've been driving the car it would just quit on me in the middle of the road and i'd have to get a jump start please help
Old 09-11-2005, 09:15 PM
Ragtop_Renegade's Avatar
Ragtop_Renegade Ragtop_Renegade is offline
Re: fiero stalls
How old is your battery? It sounds like you may have a cell going bad. Nasty, corroded connections at the battery or power distribution block (mounted on the right inside quarter, in the engine compartment) May be a contributing factor as well. Find a shop that offers free charging system checks and you'll probably find out what's doing it to you. To save a few bucks, you can take the free results home and make the repair yourself.
Wanted to buy:
86-88 Fiero GT, 5 speed, fixer-upper. Blown motor, no motor? No problem! Rusty unibodies need not apply.
74-79 Ramcharger or 100, slant or no motor - not interested in v8 - Overdrive 4 is a big plus, NO hopeless rust buckets!!!
3Rd gen F body floor pans/camaro door skin (L)
Why is it I see so many "Proud to be an American" bumper stickers on the backs of cars made in Japan or Korea??????
Old 09-11-2005, 10:25 PM
new
both battery and the pdb are relatively new although there is nothing holding down the battery it moves around
Old 10-27-2005, 05:01 AM
85fierogirl 85fierogirl is offline
Send a message via AIM to 85fierogirl Send a message via MSN to 85fierogirl Send a message via Yahoo to 85fierogirl
Re: fiero stalls
I am having the same problem I think
Old 11-18-2005, 12:14 AM
FierceGT's Avatar
FierceGT FierceGT is offline
Send a message via MSN to FierceGT
Re: fiero stalls
Check all your battery cables to make sure they are tight and not corroded. The ends that hook to the battery are especially prone to corrosion since they are exposed to the weather.
Old 11-20-2005, 02:26 PM
Old Lar's Avatar
Old Lar Old Lar is offline
Re: fiero stalls
Make sure you have good battery ground. If the battery is getting discharged, you may have a small drain somewhere in the electrical system. A PITA to locate. If the car just dies, you may have ignition problems. This could be the coil or ignition module. Both of these items have a bad habit of dieing, then cool down and then restart. If those parts are original, you may want to replace them and/or replace the entire distributor.
