Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 09-10-2005, 06:39 PM
koutroulakis koutroulakis is offline
Unhappy air conditioner
I have a 97 concorde and the air is cold but its not blowing out very hard. I don't know how else to explain it. so hopefully someon can help me out?
JK
Old 09-12-2005, 07:37 PM
Bizzy102 Bizzy102 is offline
Re: air conditioner
who do you mean by blowing out not hard? Does the blower work on hi, or does it stay the same all the time? Is your air cond automatic or dial type?
Old 09-14-2005, 07:09 AM
Re: Re: air conditioner
Its is automatic and it stays on the same level all the time. I can actually feel the air at the feet so it seems that it is stuck at the setting for the floor vents.
Jk
Old 09-14-2005, 01:29 PM
CobraCDN's Avatar
CobraCDN CobraCDN is offline
Send a message via Yahoo to CobraCDN
Re: air conditioner
JK
Run a diagnostic on the ATC
With the car running:
1] Set Temperature at 75 degrees.
2] Press and hold the Floor/ Mix / Defrost buttons untill the display blinks.
3] Let the dignosis mode complete, if there is a code it will be displyed where the temperature is. Press the panel button to see if there is mor then 1 code.
Codes:
Code Description
23 ATC Blend Door Feedback Failure
24 ATC Mode Door Feedback Failure
25 Ambient Sensor
26 ATC In-Car Sensor
27 Sun Sensor Failure
31 ATC Recirculation Door Stall Failure
32 ATC Blend Door Stall Failure
33 ATC Mode Door Stall Failure
34 Engine Temperature Message not Received
35 Evaporator Sensor Failure
36 ATC Head Communication Failure
