super license
Hey, cant someone tell me the best hints on how to beat super license 6-8? thanx.:bandit:
an excerpt from www.gamefaqs.com
VIII.) LAGUNA SECA GUIDE Laguna Seca. One of two real race tracks in the game. And by far one of the best, if not THE best track in the entire game! Not that it has anything to do with the licenses, but this is an excellent track to do your vehicle tests, (free runs) to see which are your best cars. It has an excellent combination of fast and slow turns, chicanes and is also much, much shorter than complex string! I use this track more than any track in the "Run and Settings" mode from "My Home". Anyway, back to the licenses. This license is actually a fairly tricky one, even if you are an expert on this track, unless you are an expert with the Dodge Viper GTS-R Team Oreca - a beautiful car, one of my favourites in the game; although I don't use it much, in fact hardly at all. Because traction control is turned off, cornering with this car makes for quite a change from sliding easily into the corners at 200 kph in a Formula 1 car! I suggest you win this car (complete Amateur league), or maybe if you have the American / Japanese version, you can buy it. Get used to the handling and cornering abilities, with traction control off. FIRST!! Set a few laps, and then join in the demo drive and compare it to your ghost, and study the computers driving - braking, accelerating, the usual. For the first corner, brake where the computer does, and then turn keeping on the accelerator, but stay of the kerb as your car will spin out of control. Make us of the steering to correct oversteer. For the second turn, brake for a split second, and then get back on the gas straight away, hug the kerb, and shoot to the left of the next mini-straight. Follow the same procedure, except, instead of braking, get off the gas and then back on. The left turn requires a little more accelerator / brake work. Go as far to the right as you can. Brake, and then get back on the accelerator, making occasional use of the brake to prevent you from going off the track, turning left during this. Head to the right again. The next turn requires you to be as far to the right as possible, and then you need to swing across over the kerb to the left at full speed, and end up on the right side of the straight approaching the corkscrew. THE CORKSCREW... brake as late as possible, but early enough to slow enough to turn without skidding of the track. I am not sure how the computer manages to brake so late and still make it through the corkscrew, but unless you are going for a gold, brake a little earlier just to be safe. Turn left, and then, gently accelerating, drive over the right rumble strip, now at full speed. For the next curve, you can actually take it at full speed with a little practice. Stick to the right side at the exit of the corkscrew - so far to the right that you are just about off the track, and then swing at full speed onto the left through the curve. The final sector... for the second last turn (after the curve), simply follow the demo drive - brake and then accelerate quickly, turning right. For the last turn, early braking is required, and acceleration must be done carefully, as you will spin if you accelerate too quickly, ruining what might've been a perfect lap, or more importantly, your chances of getting the license. That might seem a bit detailed and difficult, but once you know what to do, it'll be very easy, and just a matter of taking the right lines. Fairly easy.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Thanx for the reply, ive been dieing to get this stupid thing!
i played forever yesterday trying to get the gt40 around seattle quick enough....
My dream, feel free to donate some money to help
