Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-10-2005, 02:53 PM
crod72 crod72 is offline
caliper bolts
Has anyone ever had a hard time getting the caliper bolts off?
Old 09-10-2005, 05:06 PM
surferfletch surferfletch is offline
Re: caliper bolts
Yup. Broke a 1/4" socket trying to get it off with the wrong but only available socket set. Those caliper bolts have to be lubed or they'll freeze up. Will something longer work?
Old 09-10-2005, 09:10 PM
Cat Fuzz Cat Fuzz is offline
1/2 inch drive breaker bar, the only way to fly.
Old 09-11-2005, 06:18 PM
wb4lbg wb4lbg is offline
I broke a 3/8" drive 17 mm socket on mine. I think it was the first time they had ever been removed. I was trying to remove the rotor. To do this on a '99 you have to remove the bracket the caliper mounts to also.
These were 22 mm heads. A ratchet wouldn't do the job and I only had a 3/8" drive socket. I put it on a 16" 1/2" drive breaker bar with a 1/2 to 3/8 adapter. I sheared the adapter off trying to get these bolts loose.
Score Isuzu 1 -- Craftsman Tools 0.
But seriously, anybody have any recommendation for getting these bracket bolts loose? I've got a 1/2" impact gun but there's no room under there to use it. Would heating the bracket with a propane torch help?
Thank!
JWS
'99 Rodeo LSE 4WD
'00 Escort ZX2
'00 Olds Silhouette
Old 09-11-2005, 11:18 PM
Try using the 1/2" drive impact socket on the 1/2" drive breaker bar. Place it on the bolt head fully, stand on breaker bar and bounce till you break it loose.
