Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-10-2005, 01:57 PM
93buicklesabrelmtd's Avatar
93buicklesabrelmtd 93buicklesabrelmtd is offline
CODE 32! How do I FIX
1995 GMC Suburban 1500 with 5.7L engine.
The light has been coming on and going off on its own.
Sometimes it may stay on as long as 15mins.
I pulled the codes for ODB1 and got 1 code, number 32!
I know its something to do with the EGR system/solenoid.
How can I go about fixing this problem??
Need fixed sooon!!!
Another thing, is there supposed to be a constant vaccum leading to the Purge Canister? Cause I unplugged and wasnt NO vaccum there at all! There was a vaccum on the PCV valve.
Please help.
Old 09-10-2005, 05:24 PM
poconoracing poconoracing is offline
Send a message via Yahoo to poconoracing
According to the info I have Code 32 is a Non responsive EGR Valve.
Check the connections and replace it if needs be.
Old 09-15-2005, 09:44 AM
Re: CODE 32! How do I FIX
So I should replace the EGR valve and not the solenoids?
I need to get this fix soon, any help is appreciated!
Old 05-24-2006, 12:12 PM
jsnowbordr47 jsnowbordr47 is offline
Check the valve to see if it hold a vacuum, and replace if necessary, then disconnect your battery and turn the ignition on for 30 seconds. That clears the code. If light comes back on then check the solenoid.
