Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 09-10-2005, 11:41 AM
lkgage lkgage is offline
944 fuel filter
i have just put a new DME relay for my porsche 944 and it has a fairly new fuel pump. when i first got a few weeks ago we started it up after putting it on a battery charger and drove it around for a few minutes. we then shut it off the check the levels of everything in the engine and now when we go to start it it cranks but wont fire. could it be that the fuel filter got clogged with the old gas in the tank so now it doesnt get any fuel? could someone please tell me where the fuel filter is located and how i can check to see if it is clogged.
thanks
Old 09-10-2005, 12:14 PM
pearldrum944's Avatar
pearldrum944 pearldrum944 is offline
Send a message via AIM to pearldrum944
Re: 944 fuel filter
Did you make sure that you have spark? Is the fuel pump running for sure? The Fuel filter is about 2 feet farther down the fuel line than the pump, it's a cylinder mounted more toward the middle of the car and a little higher. The only way to really check it is take it off and try to blow through it.
'83 arctic silver porsche 944
My gallery.
A better Porsche forum
Old 09-10-2005, 12:17 PM
Re: 944 fuel filter
You could try to loosen the nut on the front of the fuel rail while you are turning over the engine. If fuel eventually starts working it's way around the threads you are getting fuel pressure.
My gallery.
Old 09-10-2005, 12:30 PM
yes we know it does have spark because we drove it around and it will start and run for a few seconds off of a shot of starter fluid. how do you suggest making sure that the pump is working. it appears to almost brand new
thanks
Old 09-10-2005, 12:35 PM
Re: 944 fuel filter
When someone turns the car over have another person by the pump. You should be able to hear it humming or feel it vibrate.
My gallery.
Old 09-10-2005, 01:08 PM
does anyone know how much a new fuel filter costs or if it is possible to just clean out the old one
thanks
Old 09-10-2005, 01:13 PM
are there any other fuses that would keep it from getting gas in the fuse box? and can someone tell me a website that i can go to so i can see what each fuse goes too?
thanks
Old 09-10-2005, 01:36 PM
Re: 944 fuel filter
I believe the filters are about $18. Don't bother trying to clean it, just get a new one. There is one fuse for the fuel pump...I'm not sure where it is. If you have the porsche manual that came with the car it will tell you.
My gallery.
Old 09-10-2005, 03:35 PM
no we dont have it that is why i was wondering about a guide i can look at on the internet
Old 09-16-2005, 08:49 AM
Indycarlover Indycarlover is offline
Re: 944 fuel filter
Yes, just replace the old one...
Although that doesn't sound like the problem...Maybe a relay somewhere?
Good luck/skill
Oh, you might try the question over at the Pelican Parts Porsche board too. Good guys there.
Owner: Autofreefinders.com
A for sale by owner online auto mall
Over 10 years in business
Indianapolis Indiana
Drive: 86 Porsche 944 & 90 300 ZX
