Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-10-2005, 10:26 AM
jjm01o jjm01o is offline
Twilight sentinel 93 SSEi
Anyone know where the twilight sentinel sensor is located ? Mine has quit working and no doubt needs replaced.
Old 09-12-2005, 07:08 PM
randman1's Avatar
randman1 randman1 is offline
Re: Twilight sentinel 93 SSEi
It's the sensor on the top of the dash on the far left side. It's flat, black and has a small "eye" in the middle. If you have Electronic Climate Control, there is also a solar sensor in the middle of the dash. This is a little dome looking thing and has nothing to do with the sentinel.
Mine doesn't work either so I took a quick look at the manual. There was two pages of diagrams. Since I didn't have much time, I put it off. That was a month ago and I still haven't had time to dig into the car.
One of these days... maybe
Old 09-13-2005, 04:46 PM
Thanks, I'll look into it.
I've been replacing sensors like crazy lately. Right now I'm not sure if I want to be bothered with it. The other factor I wonder about is cost. Oh well.
Old 09-13-2005, 08:23 PM
randman1's Avatar
The sentinel sensors can be tested easy enough with a multimeter. It is just a variable resistor depending on how much light it sees. If yours tested to be bad, you could replace it with a junk yard one for $5 I bet. Bring the multimeter to the junk yard so you don't but a bad one.
there's a lot more to the circuit than just that sensor though and they don't go bad too often. It might just be partially unplugged. that's easy to check too.
