Old 09-10-2005, 09:34 AM
gtmarko gtmarko is offline
Send a message via AIM to gtmarko
81 mustang
hello have a 1981 mustang with a 2.3 carburated runs rough any ideas what to look for as to the trouble with it running bad. new plugs installed
Old 09-10-2005, 10:48 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 81 mustang
Checked the timing?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-11-2005, 07:16 AM
Re: 81 mustang
timing was checked and new timing belt also was installed, but couldn`t get the marks to line up on the sprockets. the crankshaft and auxiliary sprockets line up ok, but it`s always off one tooth on the camshaft sprocket, either ahead or back one .i`m lost on why this happens any ideas?
Old 09-12-2005, 12:48 AM
mastermech mastermech is offline
Re: 81 mustang
the timing is off, the marks need to line up and if you have plastic timing cover the pointer is most likely plastic look for a broken pointer for the camshaft mark. if I remember right there were three pointers where the mark on the camshaft could point to you want the one in the middle, the one to the left advances the timing the one on the right retards it. hope this helps. done this job a lot!
Old 09-12-2005, 07:14 AM
Re: Re: 81 mustang
the sprockets : cam, crank, and the aux. all have a triangle mark on them. the pointer is made of metal . there`s no plastic pointer on it. also the motor runs but could i have the distibutor in 180 degrees off?
Old 09-12-2005, 02:28 PM
need help with the timing marks on the cam to line up with the crank
Old 09-12-2005, 05:24 PM
i read your message. here's what you do. turn the engine to the 0 degree mark on the crankshaft and look where the rotor is pointing on the dist. if you look from the driver side fender it should be pointing about the 7:00 position, and look at the timing mark on the camshaft, pull the little cap on the timing cover. all marks need to be dead on, if the pointer you mentioned for the camshaft is off. just one or two teeth off and the engine will run but badly. also make sure your spark plug wires are correct the order is 1-3-4-2 clockwise rotor turn. do you have a haynes for chilton book? Lastly, when you changed the belt did you make sure you were on the compression stroke of the #1 cylinder, if you were on the exhaust stroke you will be 180 out. and make the camshaft mark as close to perfect as possible (sometimes the mark is casted a bit off)
Old 09-13-2005, 12:12 AM
SkylineUSA's Avatar
Re: 81 mustang
Greg,
What mech wrote up, would be exactly what I would do. I think its your timing as well, but it could be something else, but I doubt it.
Old 09-14-2005, 04:31 PM
Re: Re: 81 mustang
Originally Posted by SkylineUSA
Greg,
the mark on the cam is on the tooth , but when the pointer lines up the notch is always lining up with pointer could there be something wrong with pointer or cam, if so how do i fix it thanks greg
