Old 09-10-2005, 09:16 AM
Mike Gentry Mike Gentry is offline
Major Oil Leak 3 cyl.
I have seen this on the forum before but cannot contact the person that had the problem. After about ten minutes of running, oil drips out of the oil pan seal and crank sensor area, about a quart per half hour. Is this heat related or pressure related? New oil pan seal does not help. Help! Does anyone have a fix. 96 geo metro, 96k miles 5 speed.
Old 09-10-2005, 03:41 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Major Oil Leak 3 cyl.
sounds like engine might be building up pressure, replace the pcv valve and make sure the hose that goes from valve cover to pcv and air cleaner is not plugged. if all that looks ok the take the hose off the valve cover and start engine, should feel air coming out when its running, if not the the valve cover is gummed up. if all this is good then you have a bad oil seal somewhere
