Old 09-10-2005, 08:56 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
engine studdering
Hey guys, this isnt a camaro im talking about, but im talking about the same engine that was once put in the camaro.
Anyways, it is the iron duke.
I spilled brake fluid all over the wiring and stuff, so i wanted to clean it off, and i gunked the engine. I sprayed it off, and let the engine idle for 15 minutes like the directions said to.
I went to drive the car today, and it seemed to studder after i got done stopping at a stop sign, and i was pulling out. It stalled out once, and studdered and almost stalled when i was trying to go after the light turned green.
I first thought the problem was when i had the AC on only, but i turned the AC off, and it did studder a bit. It seems to only be shuttering when the car has been idiling for a while (like waiting at a redlight) And after driving it around for a while, it seemed to quit, and only happen when the car was idiling.
WHen i say studdering, it feels like in the car, when you let the clutch out too fast, and dont get it enough gas, the car is shaking, and studdering trying to stall out.
Im assuming that some water got in the distributer cap, and isnt letting it fire right.. but i just wanted your guy's opinions.
The distributer is REALLY hard to get at, or i would of already taken the cap off, and seen if there was water in it.
I dont drive the car much, and if the problem is water in the distributer cap, is there any harm in letting the water evaporate by itself?
Thanks.. and if needed, the car is a 1985 chevy celeb.
Old 09-10-2005, 10:07 AM
CamaroRS92 CamaroRS92 is offline
Re: engine studdering
sounds like you steamed your distributor cap .
It wont evaporate on its own - the moisture is trapped under there.
You will need to remove the cap and dry it out. CRC556 or WD40 works well to displace the moisture.
Old 09-10-2005, 01:04 PM
steamed the cap?
what does that mean?
Old 09-10-2005, 01:11 PM
bag91's Avatar
bag91 bag91 is offline
Im guessing water in your cap.
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 09-10-2005, 05:24 PM
Spraying cold water on a warm engine = Steam
Old 09-10-2005, 05:25 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Funny ...Steamed Cap. NO its not the case. This a carb right. As i understand its missfiring.
1 Bad wire
2 Bad plugs
3 Bad cap (not likely theres no way that water would not evaporate from there when the engine is hot)
4 Vacuum leak
5 Ignition module.
6 Carb problem
7 Stuck lifters (not likely)
Old 09-10-2005, 07:22 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Should be.. I think 86 was when Chevy made everyone go FI.
Old 09-10-2005, 08:28 PM
no, it isnt a carb.
it is kinda of funny how everything was fine, then i sprayed the engine down, and it happens.
also, how would water in the cap do this? I mean, the same thing happened in my camaro.. there was water in the cap, and a few cylinders wernt firing.. i mean, we have hard water, it is very conductive.
Old 09-12-2005, 01:47 AM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
moisture in the distributor cap will/would cause the problem you are having. moisture (in the air inside of the cap) prevents the spark from jumping from the terminals like it should. have you ever rubbed your feet on a carpet and gotten a static shock when your hands are wet? No, you haven't. It only happens when your skin is dry. The same applies to distributor caps (carbed or not). This is probably you're problem.
supervisor1886, you really shouldn't misinform people like that.... moisture in the cap is a pretty common problem, and it doesn't easily evaporate even if the engine is hot.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 09-12-2005, 11:58 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Re: Re: engine studdering
That is very true. I know from my days of Van de graaff building that moisture is the enemy. Especially in Florida where its extremely humid. One thing I did when I was building VDG's was to create a heat box. Basically a sealed box with a high heat light bulb. Home-made van de graaff machines are a little more finicky than a distributor though.
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
