Old 09-09-2005, 09:29 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Need Help! Looking for new shocks
I have a third gen that's been lowered too much. It currently has a pair of KYB GR2s and the coil springs look shorter also. Does anyone know where I can find some good sports shocks to get to oem height?
Old 09-09-2005, 10:27 PM
Dyno247365's Avatar
Re: Need Help! Looking for new shocks
I fixed my post, I'll never do that again. I swear
Old 09-09-2005, 11:03 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
my old camaro has koni shocks and eibach springs that take it down 1". Its not too low and not too high. I like it. Except you feel EVERY bump in the road. And you want to avoid brick roads at all times. So it would all be preference as to what kind of firmness you want. It was a rough ride but man did that thing ride on rails. The roughness could be eased by adjusting the firmness a little cuz I had them all the way tight. I have heard that kyb's are a little better in that reguard. You say the car has coil overs right now? Thats pretty cool.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 09-09-2005, 11:45 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
i have the gr2 struts too. but i also have kyb gas-a-just shocks in da back.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 09-10-2005, 10:45 AM
Dyno247365's Avatar
The problem is that the rear has normal shocks but the front is lowered and I can't turn the wheels much, they're rubbing against the control arms.
Old 09-11-2005, 02:01 PM
Dyno247365's Avatar
Does anyone ride on oem height? What I was hoping to find were some racing shocks that kept the car high enough...but I still can't find anything, just a lot of lowered Irocs.
Old 09-11-2005, 02:58 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Why bother it looks all right. But are there any aligment issues?Ho doest handle?
All these stuff on it is pretty expensive.
Old 09-11-2005, 04:09 PM
Dyno247365's Avatar
Re: Re: Need Help! Looking for new shocks
I try to turn the wheel and the handling is like a tank. Here's the reason,
and these are the struts on there now--->
Old 09-11-2005, 08:16 PM
Dyno247365's Avatar
Alright, I found out what the problem was. The car had been sitting for a few years and since these are gas shocks, the gas completely seeped out of them and the front end fell, which made the control arms low and the tie rod etc were misaligned.
So yeah the car's lowered alright.
Old 09-11-2005, 08:23 PM
Viper_Storm's Avatar
Viper_Storm Viper_Storm is offline
Send a message via AIM to Viper_Storm Send a message via MSN to Viper_Storm
just grab a couple of replacements and swap them in and you should be alright.
All Throttle, No Bottle!
Torque Makes You Go... FAST!
Horsepower Is For Braggin Rights.
Money talks, But all mine ever says is Goodbye
~Viper
"twospirts" / "TS" - Definition: Obsolete
Old 09-11-2005, 08:29 PM
Dyno247365's Avatar
I wish I knew that in the first place lol
Old 09-22-2005, 11:55 AM
scoobytuff scoobytuff is offline
If you are not happy with the ride of the car lowered,and the wheels rub the control arms when turned, is it really worth it? To me it wouldn't be. This is the kind of crap that makes you not want to drive your car. If new shocks don't bring it up enough, try a less lowered spring. I know this is a no brainer but it doesn't matter how expensive the pieces on the car are if you don't like it. The reason I bring up expense is because in one of the other post someone mentioned that those were pretty expensive peices. Ride stance is not as important as handling, and if it feels like a tank then not only are the shocks to blame maybe the springs too. If the springs suck you will shorten the life of your shocks.
Old 09-22-2005, 05:52 PM
Dyno247365's Avatar
you said what needed to be said Lemme give a for instance to everyone here. The cheapest you can get are Gabriels and Monroes, for around 100-200 for the set. Everyone makes a big deal out of KYB's but it's the AGX's that are really worth it. the price of shock absorbers/struts will jump in between models and the hard part about this is determining if you should buy the best shocks a cheap company sells. The bottom line, IT'S FRICKIN HARD TO SHOP FOR SHOCKS
I'm going to determine now whether I need new springs, but mostly because they were crushed/compressed by the engine bay lol. They may still work though.
Old 09-22-2005, 06:49 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
i have oem front springs that I don't need if you want them.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
