Old 09-09-2005, 06:10 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
What will happen if i do this?
what if i unpulg the safc ( just from the part where you seperate the chord) from my car and turn on the car? What are the effects of doing so? Can this be bad for my car? -Ray
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 09-09-2005, 06:31 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: What will happen if i do this?
Just run the injector pulse based off the factory fuel map. Why? Do you have larger injectors?
DSM geek
Old 09-09-2005, 11:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
Simply unplugging the AFC doesn't work. The car will run, but in some half assed safe mode. Essentially the same thing as when you forget to plug in the MAS... You need to reconnect the airflow meter's signal wire that the AFC intercepts. This is covered in the AFC's instructions and on the sites like RRE that list thier own instructions. Most poeple put male/female spade type connectors on to make this easy to do on the side of the road, and I believe some are included with the AFC, but it's been a while.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
