Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-09-2005, 06:15 PM
catfish263 catfish263 is offline
1995 dakota no spark at coil no fuel 3.9
went to use my truck yesterday and it won't start. I pulled a plug checked for spark-nothing. checked the wires leading to the coil - no voltage. I also don't think its getting fuel. I noticed when you turn the key to run before cranking the check engine light does not come on. when the check engine light comes on it starts.Is the computer getting juice ? How can I tell? Any help----thanks
Old 11-13-2005, 03:06 PM
jon_norris jon_norris is offline
ive been having the same problem w/ my truck, have u found the problem yet?
Old 11-14-2005, 04:07 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1995 dakota no spark at coil no fuel 3.9
chances are, your ASD relay is acting up. It's located under the hood in your fuse box. Try swapping it out with the A/C relay and see if it fires up then. If the ASD trips, usually there is something that trips it, such as the crank sensor. To find out if you have any engine codes in memory, turn your ignition key on/off 3xs ending in the "ON" position. The check engine light will flash, if it flashes twice then pauses and flashes another 4xs, that's a code. 24. If you get a code 12, that means your battery has been disconnected w/in the last 50 start-ups. The final code you'll get a 55 which is an "End Of Code" message. Try the codes first, then move on to the ASD relay.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
