Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 09-09-2005, 05:07 PM
postcoke2 postcoke2 is offline
Exclamation lack of power with check engine light
Any feedback would be greatly appreciated here! I have a 2001 Tacoma reg cab 4 wheel drive and recently the check engine light came on. It shakes roughly when it idles and has lost power. I assume it is running on three cylinders and have had the spark plugs changed. no help there. Brought to the dealership and they cleaned cylinder 4 connection at coil insulator. This helped for about 3 miles then back to shaking and check engine.... Anyone have any ideas and is anyone else fed up with their Toyota dealership service actions?
Old 09-09-2005, 10:21 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: lack of power with check engine light
What code is stored in your computer - related to the "Check Engine" light?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-09-2005, 10:38 PM
Re: Re: lack of power with check engine light
Not quite sure how do go about getting that code i guess... the dealership didnt even bother doing a diagnostic on it. where do i find it?
Old 09-09-2005, 11:17 PM
Brian R.'s Avatar
Resident Chemist
Bring it to Autozone if you have one in the vicinity. Dealer or a friendly mechanic would be able to get that for you also.
Old 09-13-2005, 10:45 AM
cts24 cts24 is offline
I have a 95 Taco and had a similar thing happen to me. Took it to Auto Zone, put it on a code reader and found out the cat. converter was going bad. Don't know if this helps but it might give you a starting point.
Good luck!!
Old 09-13-2005, 10:49 AM
Re: Re: Re: lack of power with check engine light
Good luck!!
Thanks all, seemed to be a bad injector of all things.
Old 09-13-2005, 04:10 PM
Brian R.'s Avatar
Resident Chemist
That's a cheap fix. Good luck...
